1) Find your CD burner device ID:
cdrecord -scanbus
So in my case, "5,0,0" is the device id of my DVD burner.scsibus5:
5,0,0 500) 'HL-DT-ST' 'DVDRAM GSA-4120B' 'A111' Removable CD-ROM
5,1,0 501) *
5,2,0 502) *
5,3,0 503) *
5,4,0 504) *
5,5,0 505) *
5,6,0 506) *
5,7,0 507) *
2) Here are some tasks and their commands:
Extract CD and store as "data.bin" image:
cdrdao read-cd --device 0,0,0 --driver generic-mmc audiocd.toc
use freedb (aka cddb) for this:
cdrdao read-cddb --device 0,0,0 --driver generic-mmc audiocd.toc
cdrdao write --device 0,1,0 --speed 8 --driver generic-mmc:0x10 audiocd.toc
on the fly copy:0x00000010: Enable CD-TEXT writing.
This must be done explicitly because there is no way to detect if a recorder supports CD-TEXT writing. Trying to write CD-TEXT data with recorders that do not support this feature usually results in an error message at the beginning of the recording process and in real write mode the medium will be unusable.
cdrdao copy \
--source-device 0,0,0 --source-driver generic-mmc \
--device 0,1,0 --driver generic-mmc \
--on-the-fly \
--with-cddb
Additional information:
- More infos about drive models and drivers can be found on the cdrdao homepage
- Howto: Duplicate Audio CDs using cdrdao (ubuntuforums)
- /usr/share/doc/cdrdao/README.gz (if you're on e.g. Debian, Ubuntu)
