I'm currently evaluating if it's a bug and if it's still an issue in v6.5.8-4 (Dec 2009).
In order to compile ImageMagick with JPEG 2000 support, I've had to install the following packages:
sudo apt-get install libjasper-dev libjpeg62 libperl-dev
./configure --prefix=/opt/imagemagick --with-jp2
make
If JPEG and JPEG-2000 support is properly enabled, the output of ./configure should contain these lines:
If something went wrong, these formats will be disabled and look like this:JPEG v1 --with-jpeg=yes yes
JPEG-2000 --with-jp2=yes yes
Without the libjasper-dev and libjpeg62 package, they're both "no" - regardless if you switch support for them on or not.JPEG v1 --with-jpeg=yes no
JPEG-2000 --with-jp2=yes no
Installing it seemed a bit strange, because you can't just install with "checkinstall" as root in one step. I've created the target folder as a regular user and then ran "make install" twice:
mkdir /opt/imagemagick
sudo chown myuser:myuser /opt/imagemagick
make install
sudo checkinstall make install
