Using Thunar's built-in "custom actions" editor, I've written a small script and then added custom actions for Thunar.
1) The bash-script
This small wrapper script is necessary, because the filename manipulation (e.g. remove '.gpg' file suffix when decrypting) was not possible by the shell thunar's custom actions are executed in.
#!/bin/bash
FILE_IN="$2"
DIR="$3"
case "$1" in
encrypt)
echo "not implemented, yet."
decrypt)
FILE_OUT="$DIR/$(basename $FILE_IN .gpg)"
echo "Decrypting '$FILE_IN' to '$FILE_OUT'..."
cmd="gpg --output '$FILE_OUT' --decrypt '$FILE_IN'"
eval $cmd
echo ""
echo "SYNTAX: $0 (encrypt|decrypt) <filename> <dirname>"
echo ""
echo "<filename>: Use %n"
echo "<dirname>: Use %d"
echo ""
sleep 5
esac
2) Decrypt:
Add the following custom action in Thunar:
xterm -iconic -e /usr/bin/thunar-gpg decrypt %n %d
