Script to sort JPG by metadata date
This small bash script sorts JPG images recovered using foremost or scalpel.
Their file timestamp is useless, since all recovered files have the current date/time.
Most cameras write the date inside the file as metadata in the form "YYYY:MM:DD".
This script sorts them into a single folder per-month:
#!/bin/bash
ACTION="$1"
FILETYPE="$2"
DIR_OUT="${3:-.}"
YEAR_BEGIN="${4:-1970}"
YEAR_END="${5:-3000}" # Warning: Susceptible to Y3K bug.
case "$ACTION" in
    years)
        echo "Begin: $YEAR_BEGIN --- End: $YEAR_END"
        YEAR="$YEAR_BEGIN"
        while [ $YEAR -le $YEAR_END ]; do
            MONTH=1
            while [ $MONTH -le 12 ]; do
                TIMESTAMP=$(printf "%d-%02d\n" "$YEAR" "$MONTH")
                TIMESTRING=$(printf "%d:%02d:\n" "$YEAR" "$MONTH")
                echo ""
                echo "Timestamp: $TIMESTAMP"
                TARGET="$DIR_OUT/$TIMESTAMP"
                echo "Target: $TARGET"
                MONTH=$(($MONTH+ 1))
                mkdir "$TARGET"
                CMD="grep -l \"$TIMESTRING\" *.$FILETYPE | while read f; do mv \"\$f\" $TARGET; done"
                echo "$CMD"
                eval "$CMD"
                #Remove folder if empty:
                rmdir --ignore-fail-on-non-empty "$TARGET"
                sleep 1
            done
            YEAR=$(($YEAR + 1))
        done
        echo ""
        echo "SYNTAX: $0 (ACTION) FILETYPE DIR_OUT YEAR_BEGIN YEAR_END"
        echo ""
        echo "Example:"
        echo "  $0 years jpg out 2014 2019"
        echo ""
        echo ""
esac
