sFTP: Restrict SSH users
Postby ^rooker » Thu Sep 07, 2017 2:28 am
This HowTo shows how to setup a Debian/Ubuntu based Linux server in a way that allows some users to have full SSH access, while others can only access their home folders by sFTP.
NOTE: The first steps (1-3) must only be executed once per system. :!:
1) Create the group "ftpusers"
$ groupadd -r ftpusers
2) Add "sftp-server" binary as shell:
As root run:
$ echo "/usr/lib/sftp-server" >> /etc/shells
3) Modify your sshd_config for chroot:
Add the following block to your /etc/ssh/sshd_config file:
# Restrict FTP-only users:
Match Group ftpusers
ChrootDirectory /home/%u
X11Forwarding no
AllowTcpForwarding no
ForceCommand internal-sftp
Don't forget to restart your sshd for these changes to take effect:
$ service ssh restart
4) Create a new user
...and add it to "ftpusers", and change its shell to "sftp-server".
$ usermod -a -G ftpusers USERNAME
$ usermod -s /usr/lib/sftp-server USERNAME
Then set root as the owner of the USERNAME's home folder. This is required for chroot to work.
$ chown root ~USERNAME
$ chmod 755 ~$USERNAME
That should be it. 8)
Now you can serve sFTP accounts without worrying about users wandering around on your server...
  • 0
BASH Script
Postby ^rooker » Thu Sep 07, 2017 3:25 am
If you intend to write a BASH script for creating new users like that, here's how you get the HOME folder of another user:
HOME=$(eval echo ~"$USERNAME")
:D
  • 0
Bad ownership of home directory
Postby ^rooker » Mon Oct 09, 2017 6:21 pm
If an error message like this appears when trying to login over sFTP, then things are not correctly configured:
Connection reset by peer
Could not connect to server
In /var/log/auth.log, a corresponding entry could look like this:
fatal: bad ownership or modes for chroot directory "/home/USERNAME"
The chroot target directory must be owned by root - and there must not be group write permissions to that folder.
  • 0
Return to HowTo's
Who is online
Users browsing this forum: No registered users and 2 guests
Users browsed this forum in the last 24 hours: Google [Bot] and 11 guests
cron
Reputation System ©'
