Raspberry Pi as headless audio player
Postby peter_b » Tue Dec 26, 2017 3:58 am
HowTo setup a raspberry pi (v2) as a headless audio playback device in the LAN:
1) Install Raspbian Stretch image on Raspberry Pi
2) Install Network Time Protocol daemon (ntpd):
In order to make sure that the time on the RPi is correct, install the NTP daemon:
$ sudo apt-get install ntp
3) Install MPD:
$ sudo apt-get install mpd mpc
"mpc" is the default reference client used to interact with the MPD on the commandline.
4) Configure "/etc/mpd.conf":
music_directory   "smb://your_lan_server/sharename/music"
bind_to_address   "any"
# Search for this section and change the following parameters:
audio_output {
    type "alsa"
    mixer_type   "software"
neighbors {
    plugin "smbclient"
5) Tell MPD to initialize its music database:
$ mpc update
NOTE:
I ran into massive issues with MPD being completely unreliable when using pulseaudio :(
Unfortunately, I would like to keep pulseaudio installed so I can playback from other machines (using module-native-protocol-tcp).
However, even if I remove the "audio_output{}" block for pulse, it still spawns pulseaudio... :shock: :?
Will try to figure out how to run it without pulseaudio (plain, classic ALSA-only), as this should be usable then.
Great thanks to the following sources:
  • 0
Return to HowTo's
Who is online
Users browsing this forum: No registered users and 1 guest
Users browsed this forum in the last 24 hours: No registered users and 18 guests
cron
Reputation System ©'
