1) The hplip version from the repositories is too old (at least it was when I did this: 27.Sep.2007)
2) So go to http://hplip.sourceforge.net/downloads.html and download Download the Self-Extracting Archive With Installer
3) Store it in some subdirectory (important, because it will mess up the directory you run it in!):
mkdir ~/hplip
./hplip-2.7.7.run
6) Now reboot your system (which you'll probably be asked for, at the end of the installer)
Now the prerequisites should be in place and it's time to finalize things:
Printing
1) run the HP configuration tool (this was posted in some forums, and a lot of people were wondering why they didn't have something called "hp-setup", but now you have it):
hp-setup
Scanning:
1) Find the scanner:
sane-find-scanner
2) now runfound USB scanner (vendor=0x03f0 [HP], product=0x5711 [Photosmart C4100 series]) at libusb:005:002
scanimage -L
to see if the backend loads properly. If this returns an output like this, you're done:
device 'hpaio:/usb/Photosmart_C4100_series?serial=MY76DJ12Z404J7' is a Hewlett-Packard Photosmart_C4100_series all-in-one
2b) [optional]
In my case "scanimage -L" got stuck - so I had to increase the debug verbosity level of scanimage:
export SANE_DEBUG_DLL=255 ; scanimage -L
In order to solve this, I've removed the backend config file:
mkdir /etc/sane.d/unused
mv /etc/sane.d/geniusvp2.conf /etc/sane.d/unused
Run scanimage -L again to see if the problem persists.
