I've been using ntfs-3g for quite a while without problems, except for an annoying error message that appeared for every file created on an NTFS partition:
The file is created without problems, but applications receive an error as feedback, thus leading to false (and annoying) warnings (e.g extracting files with Ark claims that the files are broken).Could not change permissions for ...
The error is caused by the system trying to modify ownership/access rights for the created file according to the umask/gid options in /etc/fstab.
My erroneous fstab line looked like this:
/dev/sda1 /media/storage ntfs-3g defaults,user,umask=007,gid=46 0 1Changing the mount options to the ones below makes the error message go away, because the system's not doing any chown/chmod anymore:
/dev/sda1 /media/storage ntfs-3g defaults 0 0[Additional Information]
Sometimes you see people mounting ntfs partitions with "silent" as option. According to "man ntfs-3g", this does the following:
So if you mount it with "defaults", silent is on automatically.Do nothing on chmod and chown operations, but do not return error. This option is on by default
Thanks to the following forum threads:
Could not change permissions for... (mybroadband.co.za)
Moving files and permissions (ubuntuforums.org)
