I wanted to order a 12" Inspiron Mini from Dell pre-installed with Ubuntu Hardy. The minute I ordered it, they took that model off their website and discontinued it - although I already had a valid order for it.
They were really cooperative on the phone and were helping me finding a suitable alternative: A Vostro 1320 with a 13" display, since I didn't want to have 15" or up.
I explicitely told them that I don't want any hardware hassle with Linux - and that I'm planning to use Hardy so I could expect some support from Dell (e.g. Dell-team PPA repositories, kernel drivers, etc). I checked all the components they've listed and told them that neither the wifi card, nor the graphics card, nor the gigabit ethernet (!!) NIC, nor the audio card seemed to be fluently supported under Linux.
Their reply was: "no, no. don't worry. you'll get all drivers you need from us".
Well. Long story short: Maybe I haven't found their Hardy-repositories supporting all these closed-proprietary-pieces-of-junk yet, or they by "everything's supported" they actually meant: "It's probably possible, if you compile everything yourself".
Long story short, here's my day:
1) Onboard Gigabit NIC: Realtek 8111/8168B:
The network interface eth0 showed up after a fresh install. Yeah! But it simply did not connect at all. DHCP was just running into a time-out.
Reason: It's loading the r8169 module which doesn't work with certain r8168 chipsets.
So I needed to download tar.gz archive from Realtek, but their website was down (my lucky day) - so I had to find it from somewhere else - and compile it. There were some strange problems with "invalid module format" when trying to "sudo modprobe r8168".
I don't know why, but I just had to manually copy src/r8168.ko to /lib/modules/2.6.24-24-generic/kernel/drivers/net/, because the one put there by "make install" differed (??wtf?) from src/r8168.ko. Whatever.
Then add the following line into /etc/modules:
r8168Code: Select all
blacklist r81692) The wireless adapter, Broadcom BCM4312 (as shown by "lspci"), is actually a 4315 (as shown by "lspci -nn") - which is at the moment *not supported* by the kernel driver for bcm43xx devices.
So I did the following:
# Install the firmware loader for Broadcom 43xx devices:
apt-get install b43-fwcutterThen some black magic voodoo happened, and it seems that a kernel module "wl" is now handling that device.
3) The Intel HDA soundcard worked out of the box!
Yeah, but.... only the output. There are *no* inputs showing up in alsa
Still haven't figured out how to access the microphone input yet.
Playback is super-quiet by the way, but that seems to be a known issue for snd_intel_hda devices.
4) Video playback locks up the computer immediately.
Greaaat! And I thought "at least the graphic driver works without blood donations". Oh, btw: I must admit: The display is very very very crisp, sharp and bright. excellent image.
However, I can't play any video except youtube on that machine
