I had a softraid mirroring sda1/sdb1 and sda5/sdb5. A disk failed, so i replaced it but could not remember the exact values i had used for the partition size when setting up the disks back then.
You can clone the partition table using 'sfdisk' if you have an harddisk of the exact same size as the one you want to clone (which will most likely be the case for a softraid).
The following line dumps the partition table of sda into a file:
sfdisk -d /dev/sda > partitiontable_sdaCode: Select all
sfdisk /dev/sdb < partitiontable_sdaThe following will show you if you were successfull:
fdisk -l
