After changing vim's settings to Unicode:
set fileencoding=utf-8
set fileencodings=utf-8
set encoding=utf-8
set termencoding=utf-8
ö ä ü
My terminal client (in this case "PuTTy") was not expecting unicode characters, but still iso-8859-1 (latin1).
So check your terminal's encoding. In PuTTy it's in:
"Window > Translation > Character set translation on received data"
TIP: (On Windows: You can change/check in realtime if you right-click on the icon in the upper-left corner of the putty window and select "change settings")
