Python and MIDI
Posted: Mon Jul 07, 2008 2:33 pm
I'm currently trying to add MIDI support to serial-pyio, but I couldn't find any "this is *the* one" MIDI module that is OS independent.
The closest one seems to be "PySndObj" (a Python wrapper for SndObj)
Currently, only v1.02 seems to be available for all platforms. I learned that the hard way, because for v1.3, the sourceforge download page offers 3 files - but the one with "Linux" in its name is actually for Linux on PPC (!!).
Here's what you get if you accidentially try to run that version on i386 hardware:
_sndobj.so: ELF file data encoding not little-endian
PySndObj is a dead end - long live "PyPortMidi"?
Posted: Tue Jul 08, 2008 12:19 am
Unfortunately, PySndObj was a dead end for realtime MIDI input/output handling - it seems to have only 2 objects for MIDI at all:
MidiMap and MidiIn.
I needed something like "MidiOut". :x
However, I found "PyPortMidi" which might be able to do what I want.
Unfortunately, it won't compile with Python 2.5, exiting with the following error:
pypm.pyx:357:21: Type 'PmError' not acceptable as a boolean
Here's info for a patch, lucky-me found in gmane.comp.python.pygame archive:
Yeah. To make Pyrex compatible with C++ enumerations are no longer treated as integers, though assignment of an enumeration to an integer
is still allowd. Not accepting an enumeration as a boolean value may be a bug. I would have to check. But then again it makes some sense. Just edit line 357 to be:
while(Pm_Poll(self.midi) != pmNoError):
Debian package!
Posted: Wed Jul 09, 2008 5:47 pm
I've created a proper Debian package for pyPortMidi:
python-pyportmidi_0.0.3.1-1_i386.deb
Built on Ubuntu Hardy, 32bit.
It contains binaries for Python 2.4 and 2.5
It should work on any Debian based system, as long as the version requirements of its dependencies are met. I've (again) learned a lot about Debian packaging, since Python packags are different - and even a bit more complicated when it's an extension.
pyPortMidi problems
Posted: Sat Jul 12, 2008 5:23 pm
(Py)PortMidi errors I've encountered - and possible solutions:
PortMidi call failed...
PortMidi: `Bad pointer'
type ENTER...
Double-assigning a midi port led to this error:
import pypm
pypm.Initialize()
MidiIn1 = pypm.Input(1)
MidiIn2 = pypm.Input(1)
This means that calling a function for assigning a port will fail when run twice with the same device:
def setMidiInput(device):
   MidiIn = pypm.Input(device)
This case can be avoided by freeing previous references:
   MidiIn = None # <- This calls the deconstructor of the previous assignment.
