KDE Konsole and umlauts
Posted: Wed Sep 03, 2008 11:27 am
I just ran into an umlaut-problem, again. *sigh*
The umlaut within a filename was displayed as question mark "?". I'm using bash, so doing a "ls -b *" revealed the character code "\366".
I've tried changing the terminal encoding between UTF-8 and ISO-8859-1, as well as the $LANG environment variable. The only thing that changed was that a box was displayed instead of a question mark. :?
(Unfortunately, I wasn't able to simply use "\366" instead of that character)
The file was created by someone using the "de_DE.ISO-8859-1" locale, and I was using "en_US.UTF-8". great.
Now both, the $LANG environment variable and the terminal encoding must be changed (and should match each other).
So I did:
export LANG=de_DE.ISO-8859-1
...and then changed KDE's Konsole encoding (from Default to):
Settings > Encoding > Western European (iso-8859-1)
Changing character encoding
Posted: Wed Sep 03, 2008 11:37 am
In order to get rid of non-unicode characters once and for all, you should change their encoding.
but how?
Here's a (maybe brute) way to do it:
1) Change your terminal's encoding and $LANG variable to match the special character's encoding. e.g. "de_DE.ISO-8859-1"
2) Now rename the file to be free of any special characters.
3) Reset your terminal's encoding and $LANG variable to proper unicode. e.g. "de_DE.UTF-8"
Maybe quick and dirty, but standards-compliant because it works on almost any system without the need for a special tool.
