lenovo thinkpad t61p: dvd playback problems
Posted: Mon Jan 05, 2009 3:34 pm
When the first OS you install on a IBM/Lenovo Thinkpad T61p is not Windows, you might have some problems with DVD playback, because the Matshita DVD/CDROM combo drive has region protection enabled, but not properly initialized.
Unfortunately, there is no real solution to this useless hardware crippling, because there seems to be no rpc1 (region free) firmware for those drives:
Quote from forum.rpc1.orgt=44839
$ regionset
After setting/initializing the region for this drive, the output of regionset should look like this:
If you can play DVDs now, but have broken/garbled video output and stuttering audio, you might want to check your libdvdcss2 version:
libdvdcss2 v1.2.9 seems to be broken (medibuntu repositories). Use v1.2.5 instead:
Run /usr/share/doc/libdvdread3/install-css.sh
(which currently installs libdvdcss2 v1.2.5)
Here's the output from mplayer with these problems:
$ mplayer dvd:///dev/cdrom
$ hdparm -I /dev/cdrom
Running regionset on a brand new T61p, returns the following information:It is a well known documented fact that Matshita / Matsushita / Panasonic Region Code prohibitions are difficult and most likely are unable to be circumvented.
$ regionset
As you can see, it has no region code set at all ("drive plays discs from region(s):,").regionset version 0.1 -- reads/sets region code on DVD drives
Current Region Code settings:
RPC Phase: II
type: NONE
vendor resets available: 4
user controlled changes resets available: 5
drive plays discs from region(s):, mask=0xFF
Would you like to change the region setting of your drive? [y/n]:n
idun@fiu:~$ regionset
RPC Phase: II
type: NONE
Would you like to change the region setting of your drive? [y/n]:y
Enter the new region number for your drive [1..8]:2
New mask: 0xFFFFFFFD, correct? [y/n]:
(make sure to answer "n" to avoid re-setting your region code again)Current Region Code settings:
RPC Phase: II
type: SET
user controlled changes resets available: 4
drive plays discs from region(s): 2, mask=0xFD
General information about the DVD/CDROM drive in the Lenovo T61p thinkpad:a52: error at resampling
a52: CRC check failed! 5 ( 1:58:17.4) ??,?%
a52: CRC check failed! 5 ( 1:58:17.4) 0.5%
a52: CRC check failed! 5 ( 1:58:17.4) 0.6%
/dev/cdrom:
HDIO_DRIVE_CMD(identify) failed: Permission denied
idun@fiu:~$ sudo hdparm -I /dev/cdrom
[sudo] password for idun:
/dev/cdrom:
ATAPI CD-ROM, with removable media
Model Number: MATSHITADVD-RAM UJ-862
Serial Number: HE25 xxxxxx
Firmware Revision: RB01
Standards:
Likely used CD-ROM ATAPI-1
Configuration:
DRQ response: 50us.
Packet size: 12 bytes
Capabilities:
LBA, IORDY(can be disabled)
DMA: sdma0 sdma1 sdma2 mdma0 mdma1 mdma2 udma0 udma1 *udma2
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=240ns IORDY flow control=120ns
HW reset results:
CBLID- above Vih
Device num = 1
