rsync has problems with vfat (FAT32)?
Posted: Wed Apr 01, 2009 2:59 pm
I wanted to rsync between my ext3 filesystem and my USB stick (vfat/FAT32). As long as the USB drive stays mounted: no problem. Only the differences are being transferred.
After unmounting and remounting the USB thumbdrive, rsync was convinced that *all* files had changed and transferred *everything* again. This obsoletes the whole point of using rsync.
I'm suspecting Ubuntu's default mount options for USB drives to be part of the problem.
One thing I've definitely pinned down is the "shortname=lower" option which causes all-uppercase filenames to be rewritten to all-lowercase when transferred to the USB stick.
(e.g. "META-INF" becomes "meta-inf")
This causes the case-sensitive rsync to assume files had been deleted. hmpf.
I'm still on this case.
