Recently, I've cut (instead of copied) images from an SD card to my harddisk, but the adapter caused data corruption and so the files arrived broken on my HDD and were erased from the SD card. yeah. great.
An SD card is (usually) formatted with the vfat (FAT32) or fat (FAT16) filesystem.
(note: the same procedure works for USB sticks, etc, too)
Here's what I did to recover the lost fotos:
a) Take a binary image of the partition on the SD card to work with:
dd if=/dev/sda1 of=/path/to/image/of/sdcard.bin("foremost" is a forensic tool which comes in the default repositories of major )distributions (e.g. Ubuntu).
apt-get install foremost
foremost -i sdcard.bin -T tempNote: From what I've seen so far, foremost does not preserve folder structures or filenames and only recovers the file data itself.
