Losslessly split/merge AVI video files
I know that there are plenty ways of splitting AVI files, but I needed it with a bit more reliability and precision than most others require for home use. The video was encoded using Huffyuv (so it's lossless and only keyframes), and the audio was PCM 16bit 48kHz.
So it should be possible to exactly cut the video at a given frame/sample and merge it back together later on, without a single bit getting lost.
Well, it seems that ffmpeg/mencoder/etc are not really optimized for this, but rather for handling lossy formats (like XviD, mpeg, etc..) - so I had to fiddle around with their options a bit.
Here's what I've managed so far:
1) Split the video every minute, at exactly the last frame of each minute (e.g. 00:00:00.00 - 00:00:59.24):
ffmpeg -ss $OFFSET.000 -t (($INTERVAL - 1)).999 -i $INPUT -an -vcodec copy $OUTPUT.avi
About the variables (bash-style):
  • $OFFSET: time offset where to start the video sequence. You'll need a loop around the above line to get multiple segments.
    $INTERVAL: time interval (in seconds) of each segment to extract.
    $INPUT: (full length) input video filename (e.g. "long_video.avi")
    $OUTPUT: output video filename of current video segment (e.g. "long_video-003.avi" for the 3rd segment)
About the parameters:
  • -ss: Start at a given timestamp. Format: "sec.msec"
    -t: Only "play" (=extract) a certain interval. Format: "sec.msec"
    -i: The input video filename (full length)
    -vcodec copy: Copy the video data as-is. Don't transcode or touch it.
    -an: Do *not* copy any audio. Yes. that's right: No audio - just the video. You'll see later on, why.
2) Extract the full length audio in one piece out of the original video and split it separately:
This is necessary in order to *make sure* we don't lose a single audio sample during split/merge due to muxing-synchronization oddities, depending on the tools used.
First of all, extract the audio out of the AVI file:
ffmpeg -i $VIDEO.avi -vn -acodec copy $AUDIO.wav
Now I'm using the awesome "swiss army knife of audio processing" tool "SoX" to split/merge the audio:
sox $AUDIO.wav $SEGMENT_X.wav trim $OFFSET $INTERVAL
The variables are similar to the ones used for the video. I suppose you'll get the idea how it works.
Now, in order to merge everything back, you simply concatenate the audio files like this:
sox $SEGMENT1 $SEGMENT2 ... $SEGMENT_N $OUTPUT_MERGED.wav
It's bit-proof. I've checked this, by inverting the original audio and mix it together with the merged copy. The outcome was a perfect flat-line audio.
I wish it was that easy with video with ffmpeg, but it seems that mencoder is easier for that:
mencoder -oac copy -ovc copy $SEGMENT1 $SEGMENT2 ... $SEGMENT_N -o $OUTPUT_MERGED.avi
The parameters "-oac copy" and "ovc copy" are again: "copy audio/video as-is. Don't transcode. Don't touch"
Again, I've verified that this method does not drop or multiply frames, by embedding a visual timecode (min:sec.frame) into the original video before splitting it (I've used kdenlive's embed-timecode-option for this).
Re: Losslessly split/merge AVI video files
Since recently, FFmpeg can also be used to concat and transcode multiple video segments in one step.
In my case, I'm using multiple FFv1/pcm_s16le segments (1500 frames each).
Here is an example of concatenating these "minute segments":
1) First, you create a small textfile which contains each segment filename, prefixed with "file" per line.
Like this:
file 'test-00815-000.avi'
file 'test-00815-001.avi'
file 'test-00815-002.avi'
file 'test-00815-003.avi'
2) Now this list of 4 segments can be given as input-file parameter to FFmpeg:
$ ffmpeg -f concat -i mylist.txt -vf 'movie=logo_image.tga [logo]; [in][logo] overlay [out]' -t 70 -b:v 3000k test2.mpg
As you can see, this even allows to do processing (e.g. add a logo overlay) and transcoding all in one step.
I have not yet verified frame/sample accuracy of this method, but from subjective checks it seems fine (no jumps, no clicks).
Here's another concatenation example, using bash to avoid an intermediate concat-list file:
ffmpeg -f concat -i <(for f in ./*.avi; do echo "file '$PWD/$f'"; done) -c copy output.avi
Source: FFmpeg Wiki
Split video files using FFmpeg's segment muxer
Updating this list of commands :)
Here's another way of using FFmpeg's built-in segment muxer for splitting files:
$ ffmpeg -i VIDEO_IN.avi -c copy -f segment -segment_time 60 -reset_timestamps 1 -map 0 VIDEO_OUT-%03d.avi
Arguments:
  • segment_time 60: Time in seconds. Here each segment has 60seconds duration.
  • %03d.avi: This is printf-syntax for 3-digit-zero-padded index. Automatically increased by FFmpeg.
File output will be:
VIDEO_OUT-000.avi
VIDEO_OUT-001.avi
VIDEO_OUT-002.avi
...and so on...
I have verified that this can be used for a lossless roundtrip: segment + concat (using framemd5 and FFV1).
