ISC DHCP: peer holds all free leases
For some (yet unknown) reason, I'm recently having issues with my ISC DHCP server setup. It usually runs incredibly reliable, but now, some clients just won't get a reply from the DHCP server :(
There's a nice list of ISC DHCP troubleshooting tips in an article on "prefetch.net".
The first thing to do is check the logs. By default, the ISC-DHCP server writes to /var/log/messages and/or /var/log/syslog.
Syslog seems to contain more information in some cases, and it looks like it also contains the things that go to "messages". Let's take a look:
$ tail /var/log/syslog
In my case, the requests of the failing clients didn't even show up. So it wasn't the case of a "DHCPNACK" (not-acknowledged) - but it seemed that the request didn't even reach the server.
So I tried "tcpdump" to see if the DHCP-requests are coming in:
$ sudo tcpdump -n -i eth0 port bootps or port bootpc
Well, the requests did show up:
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
15:43:50.935162 IP 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 00:50:56:97:xx:xx, length 300
15:43:53.891102 IP 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 00:50:56:97:xx:xx, length 300
15:43:58.474148 IP 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 00:50:56:97:xx:xx, length 300
15:44:01.797033 IP 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 00:50:56:97:xx:xx, length 300
15:44:07.946109 IP 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 00:50:56:97:xx:xx, length 300
...but the DHCP server didn't feel like it should respond :(
Checking /var/log/syslog again, I now had the following lines in there:
Jul 2 15:57:41 hostname dhcpd: DHCPDISCOVER from 00:50:56:97:xx:xx via eth0: peer holds all free leases
Jul 2 15:57:45 hostname dhcpd: DHCPDISCOVER from 00:50:56:97:xx:xx via eth0: peer holds all free leases
Jul 2 15:57:50 hostname dhcpd: DHCPDISCOVER from 00:50:56:97:xx:xx via eth0: peer holds all free leases
My setup is configured with 2 failover-DHCPs, where one is currently offline.
I tried to set the state of the running dhcpd to "partner-down", since the secondary dhcpd is down for maintenance for a longer time.
Thanks to the DHCPd failover article on Frederik's blog, I got an idea of how to configure the "omapi" for using "omshell".
The state of the dhcpd must be changed to "partner-down", but I'm still reading up on how to do this.
