Just ran into the following error when I tried to add an additional CalDAV calendar (source OwnCloud), but:
Adding that calendar as the first (or only) calendar works fine, but not if other CalDAV calendars already exist in Lightning...Error: [calCachedCalendar] replay action failed: null, uri=https://www.my-server.example/owncloud/ ... ser/myuser, result=2147500037, op=[xpconnect wrapped calIOperation]
Source: file:///C:/Users/me/AppData/Roaming/Thunderbird/Profiles/xxxxxx.default/extensions/%7Be2fda1a4-762b-4020-b5ad-a41df1933103%7D/calendar-js/calCachedCalendar.js
Line: 322
The error message is very cryptic, but the issue is actually that Lightning seems to handle credentials per-hostname.
Therefore, a workaround we've currently applied is to use a different hostname (for the same OwnCloud server) for a calendar that requires different credentials.
Not super-beautiful, but for my case it did the trick!
(Thanks Gil for figuring that out)
