Burp: "Could not find ssl_cert x No such file or directory"
Posted: Sun Dec 24, 2017 1:25 am
Setting up a new Burp backup server/client scenario.
I ran into the following error when I tried to connect a client to get a list (or any other 'burp action'):
I even performed a successful backup.
Before changing the hostname...
I've changed the client's hostname (cname) from "testclient" to the real hostname (in /etc/burp/burp.conf). Now the client didn't have its representation file in "/etc/burp/clientconfdir".
The previous connection only worked, because "testclient" has a pre-configured file in clientconfdir - that comes from the .deb package (repository).
See "Adding a new client" in the Burp Documentation.
After you've added a new client (and it's file in clientconfdir), clear the /etc/burp folder.
Run the following (as root - or using "sudo"):
Now, when connecting the client again (now for "the first time" again), the SSL certificates should automatically be re-generated.
This only works in version >v2.0.
$ burp -a lAlthough client connection has successfully worked before I've changed the config (see below)."Could not find ssl_cert /etc/burp/ssl_cert-client.pem: No such file or directory"
rm /etc/burp/ssl*
rm -r /etc/burp/CA
rm -r /etc/burp/CA-client
mkdir /etc/burp/CA-clientThis only works in version >v2.0.
