FFmpeg: "Too many packets buffered for output stream"
Posted: Tue Mar 17, 2020 3:43 pm
With some files, I get the following error when transcoding from FFV1/PCM/MKV to H.264/AAC/MP4:
In most cases, adding the following argument solved the issue:
In some rare cases it doesn't.
Possibly related FFmpeg issue #6375: "Too many packets buffered for output stream"
The original camera source was DV (PAL), then converted to FFV1/PCM/MKV.Too many packets buffered for output stream 0:0
-max_muxing_queue_size 1024Possibly related FFmpeg issue #6375: "Too many packets buffered for output stream"
