ffmpeg: "Could not write header for output file"
Posted: Sun Nov 12, 2006 4:31 pm
I wanted to convert a DVD (.vob) to .avi (video: MJPEG / audio: PCM), but received this error:
Unfortunately there seems to an ffmpeg-problem when muxing pcm audio in an avi. Currently I was only able to rip the audio separatedly from the video if I want it uncompressed:
Video (as MJPEG, 10Mbps)
Audio (as stereo PCM 16bit)
Must try if it's possible to save the audio directly with a WAV header instead of just raw audio (signed, 16bit, stereo)
[SOLUTION]Could not write header for output file #0 (incorrect codec parameters ?)
ffmpeg -i "INPUT.VOB" -vcodec mjpeg -b 10000 -f avi -croptop 90 -cropbottom 90 -aspect 16:9 -s 528x296 -an -y "output.avi" -map 0.0:0.0Code: Select all
ffmpeg -i "INPUT.VOB" -vn -f s16be -acodec pcm_s16be -ac 2 -y "output.wav" -map 0.1:0.0
