Kubuntu on Thinkpad T22
Posted: Mon Dec 25, 2006 3:16 am
I ran into some problems with the T22's Savage graphic card. First of all it was detected properly, but the driver being used was "vesa" which led to the following annoyances:
Thanks to a bug report, I figured out which settings to use for this monitor/graphic adapter within my /etc/X11/xorg.conf:
Settings for the Savage graphic card:
The important, additional lines are Option "BusType" "PCI" and Option "DmaMode" "None" - because they are missing in the detected config.
Settings for the monitor (it's a notebook, so it makes perfect sense to mention its settings here together with the graphic card.
Without the values for HorizSync and VertRefresh, you will end up using 800x600.
And finally, the whole section "Screen":
I've removed all the other resolutions (800x600, 640x480), because they don't make sense on a TFT anyway if they ain't its natural resolution (resizing routines of this T22's display suck)
btw: Did I mention that I LOOOOVE KNotes / TomBoy notes? They are awesome when debugging a problem.
- DVD playback stuttering
Scrolling within windows sucked! (low refresh rate)
Loading xorg driver "savage" forced me to 800x600
Section "Device"
Identifier "S3 Inc. 86C270-294 Savage/IX-MV"
Driver "savage"
BusID "PCI:1:0:0"
EndSectionSettings for the monitor (it's a notebook, so it makes perfect sense to mention its settings here together with the graphic card.
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
HorizSync 28-51
VertRefresh 43-60
EndSectionAnd finally, the whole section "Screen":
Section "Screen"
Identifier "Default Screen"
Device "S3 Inc. 86C270-294 Savage/IX-MV"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1024x768"
EndSubSection
Depth 4
Modes "1024x768"
EndSubSection
Depth 8
Modes "1024x768"
EndSubSection
Depth 15
Modes "1024x768"
EndSubSection
Depth 16
Modes "1024x768"
EndSubSection
Depth 24
Modes "1024x768"
EndSubSection
EndSectionbtw: Did I mention that I LOOOOVE KNotes / TomBoy notes? They are awesome when debugging a problem.
