Convert putty .ppk key to OpenSSH format
I had several SSH keys in PuTTY's internal format ".ppk" and wanted to use them with OpenSSH.
Since I'm using GNU/Linux (K)ubuntu, I did an "apt-get install putty".
Now you have "puttygen" and can do this:
puttygen mykey.ppk -O private-openssh -o mykey.key
(For Windows: You can probably use "puttygen" application to export it in the GUI)
Note:
If you run "puttygen --help" you can see other options like "public-openssh", etc...
Using the public-key in .ppk for SSH
In case you simply need to add someone's public key to your "~/.ssh/authorized_hosts" file, but don't have or don't want to use "puttygen", just open it in a text editor.
It will start with something like this:
PuTTY-User-Key-File-2: ssh-rsa
Encryption: aes256-cbc
Comment: My beloved key
Public-Lines: 4
Copy paste the lines following after that until "Private-Lines: x" - copy/paste them to your authorized_keys file and add "ssh-rsa" (or ssh-dsa, or whatever it says in line 1 of your Putty .ppk keyfile).
