Debian 8: mdadm mail test problem
I've setup my /etc/mdadm/mdadm.conf to send mails to my email-address if problems with the SoftRAID occur.
According to documentation found online, the following command should cause mdadm to send a test e-mail:
$ mdadm --monitor --scan --test
But in my case it replies:
mdadm: Only one autorebuild process allowed in scan mode, aborting
The command was wrong.
Use this one instead:
$ mdadm --monitor --scan --test --oneshot
Another mystery solved! :D
