During installation on a 3rd party webserver, I received this error:
running "phpinfo()" on that server gave me a listing with apparently valid session settings:Checking if sessions are properly configured: Failed!
Session Support enabled
Registered save handlers files user
Directive Local Value Master Value
session.auto_start Off Off
session.bug_compat_42 On On
session.bug_compat_warn On On
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.entropy_file no value no value
session.entropy_length 0 0
session.gc_divisor 100 100
session.gc_maxlifetime 1440 1440
session.gc_probability 1 1
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path /tmp /tmp
session.serialize_handler php php
session.use_cookies On On
session.use_only_cookies Off Off
session.use_trans_sid On On[SOLUTION]
I went to eat dinner, and when I came back I started the installation by running:
"http://www.myhost.com/modx/install/"
and it worked. I'm sorry that I haven't found a solid solution, but 2 things could have solved this:
1) waiting... and trying again.
2) calling the installation URL differently.
Anyway, this correlates with other informations I found for this problem:
http://www.etomite.org/forums/lofiversi ... t1468.html
http://modxcms.com/forums/index.php/top ... 3e5441f83a
