This check is happening in the background, but depending on your setup and use cases, you might want to re-schedule or disable it.
Here's how you can stop an ongoing check:
$ echo "idle" > /sys/block/md0/md/sync_actionCode: Select all
/etc/cron.d/mdadm#
# cron.d/mdadm -- schedules periodic redundancy checks of MD devices
# Copyright © martin f. krafft <madduck@madduck.net>
# distributed under the terms of the Artistic Licence 2.0
# By default, run at 00:57 on every Sunday, but do nothing unless the day of
# the month is less than or equal to 7. Thus, only run on the first Sunday of
# each month. crontab(5) sucks, unfortunately, in this regard; therefore this
# hack (see #380425).
57 0 * * 0 root if [ -x /usr/share/mdadm/checkarray ] && [ $(date +\%d) -le 7 ]; then /usr/share/mdadm/checkarray --cron --all --idle --quiet; fi
