I'll try to provide a short HowTo:
1) Check if you really have an Intel i915 graphics card:
- Open a terminal and enter:
lspci | grep VGA2) Check if your setup isn't already using direct rendering:00:02.0 VGA compatible controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 03)
glxinfo | grep directSo, if you have an i915 based card and "direct rendering: no", proceed with this HowTo.direct rendering: No
OpenGL renderer string: Mesa GLX Indirect
3) Load the necessary kernel modules:
Since xorg uses the i810 driver for i915 cards, the kernel modules for both cards should be loaded:
sudo modprobe i810
sudo modprobe i915- Now you must tell your system to load these modules automatically on startup. For that, simply edit the file /etc/modules and add the 2 drivers. Here's an example of what it could look like afterwards:[17180674.800000] [drm] Initialized drm 1.0.1 20051102
[17180678.224000] ACPI: PCI Interrupt 0000:00:02.0[A] -> GSI 16 (level, low) -> IRQ 177
[17180678.224000] [drm] Initialized i915 1.5.0 20060119 on minor 0
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
lp
fuse
i810
i915Here are the important parts within xorg.conf:
Section "DRI"
Group 0
Mode 0666
EndSectionHere you can see that I'm actually using the i810 driver for my i915 card, but the more important lines are "NoAccel=false" and "DRI=true". Furthermore, I've read that you must assign a certain amount of VideoRam to these cards in order for direct rendering to work.
(For i810 cards it's >= 16MB)
Section "Device"
Identifier "Intel LCD"
Driver "i810"
Option "NoAccel" "false"
Option "DRI" "true"
BusID "PCI:0:2:0"
VideoRam 65536
EndSectionCode: Select all
Section "Screen"
Identifier "Default Screen"
Device "Intel LCD"
Monitor "Monitor1"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1024x768" "800x600" "640x480"
EndSubSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "glx"
Load "dri"
Load "extmod"
Load "freetype"
Load "int10"
Load "type1"
Load "vbe"
EndSection- You can simply restart your x-server by pressing "Ctrl + Alt + Backspace"
- Log in again, open a terminal and check glxinfo again:
glxinfo | grep directImportant is the line "direct rendering: Yes".libGL warning: 3D driver claims to not support visual 0x5b
Notes
a) i915 & Xinerama = "direct rendering: No"
On my notebook, I've had my system configured to use the VGA out to connect a second monitor and use it in Xinerama mode. Unfortunately, I had to deactivate Xinerama (and thus my 2nd screen), because otherwise direct rendering could not be enabled. I simply commented the Xinerama option out in my config:
Section "ServerFlags"
#Option "Xinerama" "true"
EndSectionLiterature sources
As usual, I couldn't have done this without information from others. Here are my sources:
dri & openGL mit dem i915 (german)
http://gentoo-wiki.com/index.php?title= ... did=119204
