pd-extended: dumpOSC: "couldn't create"
Posted: Tue Jun 10, 2008 12:39 pm
Running puredata extended (v0.40.3 or v0.39.3), I couldn't run any monome related patches, because the "dumpOSC" node couldn't be created - although the necessary file existed: /usr/lib/pd/extra/oscx/dumpOSC.pd_linux
pd threw the following error:
dumpOSC 8000
... couldn't create
And the dumpOSC node had a dashed outline (red in v0.40.3).
dumpOSC acts as "non existing" node if the port it tries to bind to is already taken. I've found hints about this behavior on the puredata mailing lists.
Make sure it's really a port problem, e.g. by changing "dumpOSC 8000" to "dumpOSC 8123". If the node can be created properly, you must find out which program is already listening to the same port, by running "netstat":
sudo netstat -antpuew | grep 8000
The "sudo" is important, because you won't see root apps without it. The number "8000" is the port used in my patch - replace it with the one that's colliding on your setup.
In my case it was icecast, listening on port 8000. :)
