Their videos are often available as raw, uncompressed YUV stream, using the file suffix ".yuv" without any header.
Therefore, if you want to transcode these files using FFmpeg, you must specify the input stream's parameters, such as resolution and colorspace.
According to the technical description in their README, and thanks to a post on "digipedia.pl", here's the commandline to be used for FFmpeg:
Example 1:
Convert 625 material (=PAL) to FFv1.3 lossless codec:
ffmpeg -f rawvideo -s 720x576 -pix_fmt uyvy422 -i VQEG_PhaseI/Reference/src9_ref__625.yuv -an -vcodec ffv1 -strict experimental -slices 24 -slicecrc 0 -g 1 -pix_fmt yuv422p client/output-625.aviConvert 525 material (=NTSC) to FFv1.3 lossless codec:
ffmpeg -f rawvideo -s 720x486 -pix_fmt uyvy422 -i VQEG_PhaseI/Reference/src9_ref__525.yuv -an -vcodec ffv1 -strict experimental -slices 24 -slicecrc 0 -g 1 -pix_fmt yuv422p client/output-525.avi
